Hard to tell exactly what is considered low (voltage / amps?), but my suspicion is that you have attached your 200w panel / controller to a battery that is at or nearing full charge, where the normal action of CV is to reduce current.
Try putting a bit of a discharge on your battery and try again if amperage seems to be a concern.
If 14.1v is low, when you have set the battery for something else, like 14.4 - 14.6v perhaps, remember that a solar charge controller's temperature compensation will be active in a hot Florida summer day, and automatically reduce the voltage.
(If you are using LiFeP04, then temperature compensation should be something you DISABLE in your SCC)
Just guessing without a bit more detail of your system.
