Hello all
I have always been kinda interested in wind turbines so when I ran across one on amazon for about $140 I could not resist. 24 volt 400 watt rated , anyway tested on bench with drill running it the AC part was good 60-65 volts on all 3 legs but the dc charging side was low, 3-1/2 amps with the drill maxed out not sure if the amp gauge was reading right ether, old school mechanical with shunt built on . needless to say I ordered a inline digital. The wife was watching the battery bank voltage and it was climbing pretty fast so I'm thinking it was a lot more than 3-1/2 amps. Anyway it is up on 10 foot pole temporary running and it does work, only getting 6-7 mile an hour winds so it's just trickle charging . If it works out ok I might make a portable stand with couple couple solar panels, couple batteries, wind gen on top
