thequeenbeep
- Jul 19, 2022
- 3
I am now the proud owner of a defective Renogy 200ah lifepo4 battery. The battery is brand new and never gave a correct voltage reading from the terminals. The bluetooth readout was showing -8 to -9amps of discharge rate (while the battery sat disconnected and not actually losing power) and the cells would sometimes show up in the app but never with the correct voltage. I'm getting a replacement sent, but decided to take this one apart to investigate. Using a multimeter, the cells are showing the correct voltages, so I can only assume that the BMS is the problem. So far I can say that it looks very much like a Daly unit, but I can't find a 4s 12v 200ah unit from daly with the exact same connection layout.
- Is there a direct replacement unit available or is this a custom unit for Renogy?
- Is it possible to repair the BMS?
- If I replace the BMS and am able to get the battery functioning again, is it safe to use in parallel with the replacement battery that is being sent?
