Melissa Agar
Hi there I'm a new member,
So, I decided to upgrade my old 12 volt ss. I've got a 48 volt panel that creates 450 watts. The mppt 100/20 control box and 4 80 amp gel batteries connected in series. I've taken from one of the batteries 12 volts to my inverter which has a safety mechanism whereby if the voltage goes below 12 volts it turns off. The mppt won't charge unless my battery voltage is 5 volts below the panel which never happens.
I've come up with an idea if I connect my batteries in series to 36 volts and then get the control box to charge at 42 volts will the mppt handle this while still using the 48 volt panel. It has to disapate 6 volts.
Is it gonna show or is it gonna blow ?
Anyone know !?
Anyone know !?
