Wolfpack7483
I posted in the Vatrer thread my cell voltages, showing the runner cell almost 200mv ahead, just prior to single cell overvoltage. Will asked if I had tested the capacity of the Vatrer & I haven't. Got to thinking about that & looked at the specs on my 150w tester that I've used on 12v batteries. I didn't realize it was rated for up to 200v. Figured I could run a test in about a day & 1/2. I "re-familiarized" myself with the tester on a 12v battery &set things up for the test.
I used ring connectors for the battery terminals & xt60 connectors between the battery and the tester. I made sure both knobs on the tester were fully counterclockwise so they would be zeroed. Plugged the xt60s together to start the test. The fan immediately "took off" overspeed for a couple seconds, then sparks flew and everything died. Any idea what I did wrong? I'm attaching a picture of the tester after I removed the fan. Those are not the leads I used for the test.
