Berseker
- Mar 22, 2020
- 267
So this issue has been thoroughly discussed, but i have gone through so many bms threads, am getting a lil confused.
so here is my planned setup.
IST INSTALL
8 x 280ah 3.2v lifepo4 cells, 1.5kw 24 dumb inverter. max load on the setup is a 250w submersible pump. / 4 x 280w panels connected to a 50amp or 60amp mppt charge controller - primary charging source, as its an offgrid setup.
am confused on 2 areas. - COMMON PORT SMART BMS WITH ACTIVE BALANCER, and slightly on standalone active balancer.
for this my planned setup, which is recommended?. common port or separate port bms?. would appreciate specific alibaba or aliexpress links of any recommended bms.
a 120amp or 150amp 8s bms should be ok??
2ND INSTALL
16 x 280ah 3.2v lifepo4 cells. / 3.2kw 48v hybrid inverter - sorotec / 10 x 280w solar panels. max load would be a 1.5hp submersible pump. am thinking of getting a 250amp smart bluetooth bms, but confused if common or dual port would be ideal.
i also need a bms that will keep track of battery cycle count, in addition to other useful parameters
IST INSTALL
2ND INSTALL
