Love it!
I'm not sure the exact brand. I robbed them off a junk battery case that I got from Will. They look very similar to the Futronics brand though.Very nice…what are those connectors that you used for the terminal studs?
Its their Compact Tool Box. Home Depot for $70.I like that, which packout box is that?
Looks like weight capacity of #75.I'm not sure the exact brand. I robbed them off a junk battery case that I got from Will. They look very similar to the Futronics brand though.
It's pretty heavy. I can still carry it with one hand across the house maybe, but its not unusable.Looks like weight capacity of #75.
How’s it feel loaded up?
Yeah I wasn't looking for a high output system. I have those. This just seemed like it fit nice and I had all the components on the shelf.Cool, but 500W is not going to run any sized tools ie no skillsaws with this portable power.
Good for lower wattage longer running items - lights and I-phone chargers during black-out, camping, smaller tool below 4A 120v, ie a dremel or similar.
With those big 300Ah cells, you can power 500W continuously for over seven hours!?
-put a nylon carry strap on that thing.
Portable power. In its own cool looking carrying case! Very nice!This just seemed like it fit nice and I had all the components on the shelf.
Sounds like a Tuition Bin project! Very nice.This just seemed like it fit nice and I had all the components on the shelf.
How are the batteries held in place? Those pieces of foam? Does it shift at all?
Yeah just the foam. The box tapers a bit at the bottom and it's a damn near perfect fit. The foam just keeps from shifting etc.How are the batteries held in place? Those pieces of foam? Does it shift at all?
They are 4ga wires. Calculated voltage drop is only 0.15%, or 17mV drop at full load lol.The invert cables seem way under sized ?
You do a voltage drop calculation?
1/0 for a 500w inverter with no surge capability? Seems very overkillshould be 1/0 minimum!!!!
Looks like a nice set up.
Those M18 cleats and 3d printing are very handy.
He should've put a smiley...1/0 for a 500w inverter with no surge capability? Seems very overkill
I always feel dumber after the wisdom teeth go...Ahh got me. I'm not all there right now. Just got wisdom teeth pulled!
