manson79
was in my garage, heard a crackle, thought it was something falling, then smelled vapors. walked over there, and saw this.
My system is 3x deye 16kw inverters in parallel, to 5 batteries, connected to a battery breaker box. 5x 125a breakers and 1x 300a main breaker before it connects to the inverters. The batteries are home built, top balanced, and using DALY 250a BMS's with interface boards.
I tried for days, and NEVER got them to talk to the DEYE inverters. but we did leave it in LITHIUM mode, with the BMS"s settings set to protect the batteries.
Also, float setting was not disabled. not sure if that has anything to do with it.
INFO: the 5v on the BMS is because one of the wires melted after the fire.
this is the first time i got these batteries up to 100%
Also notice on Solar man, it was 100% at 12:10, but, the inverters were still sending 13kw for 20 minutes after it was 100%. i'm thinking overcharge? but why would it do that? and why would the BMS's not catch that? why would DEYE overcharge in first place.
Batteries were tightened, didn't detect any obvious loose terminals.
Any thoughts on what could have caused this?
