What breakers were used? Pics?
I noticed there no threaded inserts in the dual terminals- not original eves?
I would suggest supporting the entire bottom of the cells without just supporting some of the edge with that angle iron. Need to insulate everything that could short with fr4 sheets etc.
Daly have a horrible reputation here but often available for cheap.
Solark/deye lithium mode seems to imply you will be using battery comms, so it's not like choosing lithium on a victron charge Profile for example.
I have a Deye SUN-12kw hybrid inverter connected to a Seplos batteri with BMS V2.
Which Lithium mode would be correct to use when setting up the inverter?
Deye have recommendations in their "recommended battery" document, which unfortunately does not include Seplos products.
I have used Lithium mode 12 and it seems to work. Is it correct and is there any risks?
