Will this work? Any suggestions on setting up?
Panel Specification (x4)
Maximum power(Pmax) :200W
Output tolerance : ± 3%
Maximum system voltage :700V DC
Tolerance: +/-5%
SLA Battery Voltage: 16V
Type of Solar Cell: Monocrystalline
Open Circuit Voltage(Voc): 19.2V
Maximum Ystem Voltage: 16V
Temperate Coefficient of Isc: (010+/- 0.01 ) %/C
Temperate Coefficient of Voc: - (0.38 +/-0.01 ) %/C
Temperate Coefficient of Power Voc: -0.47%/C
Temperature Range: -20 ℃ to +80 ℃
Connector: MC4
see attached for the controller/charger/inverter
Batteries (x4)
Specifications
Rated Capacity (0.2C): 300Ah / 3840Wh
Cycle life: > 2000 cycles at 100% Depth of Discharge (DoD),
up to 5000 cycles at 80% DoD
Rated voltage: 12.8V
Charge voltage: 14.4 - 14.6V
Depth of Discharge (DoD): 100%
Standard charge current: 50A
Charging time: Approximately 7 hours
Max continuous charge current: 100A
Max continuous discharge current: 200A
Peak discharge current: 400A (Duration: less than 5 seconds)
Operating temperatures: Charge 0°C~50°C,
Discharge -20°C~60°C, Storage -20°C~50°C
Impedance: ≤ 15mΩ
Tolerance: +/-5%
Connector: MC4
Batteries (x4)
Specifications
Impedance: ≤ 15mΩ
