Hello I need a little bit of an assistance.
My current setup:
3x JK BMS ( JK-PB2A16S20P ) for my 3x EV car 113 Kwh battery. (1 EV car battery = 1 BMS)
15kw Solis Inverter S6-EH3P15K02-NV-YD-L
My issue: The JK Bms's are calculating and reporting wrong SOC's on a constant matter. I realize that the JK bms isn't really meant for such massive capacity (2354.17 Ah each battery) and total system 7,062 AH capacity.
And since the master BMS reports wrong (and glitchy) SOC to the inverter, the inverter keeps on shutting down the Backup power. You can read a bit more in-depth of my BMS issues of resetting the SOC from 72% to 0% to the inverter \ o /
What I'm doing about it?
Currently I'm considering of purchasing a Victron Smart Shunt to do all of my Capacity calculations. I also realize that the Smart Shunt alone can't communicate with the Solis Inverter, so I'm also considering of getting the Victron Cerbo GX communcation hub, but what I can't find is..
Will the Cerbo GX be able to communicate and work with my Solis Inverter via the CAN BMS protocol? I honestly keep seeing conflicting information all around and I honestly don't want to purchase paper weigth.
Also instead of the Victrom Smart Shunt, maybe someone has any better suggestion to my issue? I mainly need 2 things: To know the correct SOC for myself and the Inverter to retrieve decently accurate SOC data so that I do not loose power randomly throughout the usage.
My current setup:
