Dieharddan
- Jul 12, 2022
- 26
Hello, ive been running my system for 2 years without issue, i recently installed an additional battery and seems like the two batteries drain faster than with only one... im currently only using it to power a fridge, freezer, tv and some smaller devices associated with the tv. Before adding a battery i could normally get through the night with 50-60% charge left, but the past few days i wake up to both batteries drained to 0. Im no expert in this and am always learning, is there anything obvious i could be doing wrong?
3.5kwh solar panels.
Sigineer power m3048bp inverter.
2awg battery cables.
110A T Class fuse on + battery cable.
Positive battery cable is about 14" longer than negative due to addition of t class fuse.
two sok 100ah 48v server rack batteries.
Communication cable so bms controls inverters battery settings.
New battery set as master with dip switch 1 set to up and old battery dip switch 2 set to up.
Thanks
Thanks
