SOK 24V 100AH in excellent condition for sale (Bought new this year - SF Bay Area $620)
diyst99
California
I am reselling a lightly used SOK 24V 100Ah LiFePO4 Battery.
Reason for selling: I switched my newly installed 2KW solar system to 48V.
Model: SK24V100
I bought it new directly from the SOK USA website in Q1 this year.
It has Bluetooth. (latest version 8). Comes with the original box/caps/QC sheet.
Current price new: $699-$799
Selling for $590 with shipping ground included. (local pickup in the Bay Area is also possible)
Thank you
Tech specs:
7 Years Warranty.4000~8000 Cycles Life Span, Free Maintenance.
Detachable Cover, Replaceable BMS or Cells.
Connect in series for 48V Battery Bank, or Connect in Parallel for a Larger Capacity.
Built-in Smart Battery Management System.
Low Temperature Charging Cut-off.
High Temperature Charging or Discharging Cut-off.
Overcharging or Discharging Protection.
Over Current & Short Circuit Protection.
Battery Cells Auto Balance.
Charge information:
Recommend charge current: 20A
Maximum charge current: 70A
Recommend charge voltage:28.8V ~29.2V
Maximum batteries in series: 2PCs batteries.
Maximum continuous discharge current: 100A
Peak discharge current: 200A (3 seconds)
Recommend low voltage disconnect: 22.4V
BMS discharge cut-off voltage: Around 20.8V
Reconnect Voltage:>23.2V
Terminal Type: M8, 5/16 lugs
Weight: 48 lbs.
Certifications Information:
UL1973&IEC62619 for Battery cells.
Model: SK24V100
Thank you
Tech specs:
Charge information:
Weight: 48 lbs.
Now sold. Thank you!
