Sam Cho TX
Battery heating pad will only work when your system is connected to shorepower, with an active charger online, like a multiplus. One could mod it to come on when off grid, but with 9 amps or so, you get reduced usage. SFK has a setup like that.
If sensor are not working or suspect, it is easy enough to open it and stick it into ice water cup.
BMS all defective (not working as expected?), yes, that is obvious. Why do they have a new BMS V3. Why do all the dealers (a few openly admitted there is an issue). Even their competitors know about it. Come on, be honest, fix the guys BMS, send him new ones. Don't be cheap.
I have one concern regarding those who are using 24 or more volts system. There are things that must be done right. Be careful mixing voltages otherwise you will fry. Hopefully this isn't the case here.
I have the SFK v3 battery kit with the 150 BMS and the external switch with side heating pads. It works great. I just leave it on the green mode and on average I draw only 5-6 Ah for the entire day on cold days, most other days it never even runs so no amp draw. Its been that way for about 3 months now I think I'm going to turn it off now that the winter is pretty much over with in the south.
I'm glad I didn't order the 200 amp I never understood why they made heating only work on certain situations instead of allowing manual control.
I think the heating button is the way to go, add heating to any BMS you want. 150AMP is waaaayyy more than I need but strong enough to run a coffee pot.
I will post a build thread, I have a v4 kit on order with the 304 cells.
