samus250
Hello!
I have a Sol-Ark 15K with two strings connected, one in M1 and the other in M2 (so I have an empty module). I have 4 rows of 6 panels each, 24 panels total, each with a Tigo module. IIUC (I didn't install this myself), the first two rows are connected in parallel into M1, and the second set of rows are in M2 (so 6 panel in series, two sets of 6 in parallel = 12 per string). All panels are pointing towards the exact same direction, but the first two rows (M1) are at a very, very slightly more upward angle. Other than that, M1 and M2 are pretty much exactly the same. I would notice a very slight difference in power output, e.g. M2 would produce 100W more than M1 during the day, M1 would produce 100W more than M2 during the afternoon, but everything was pretty much normal. In fact, sometimes this would pull more than the 10kW total rating, I've even seen 11kW. The Sol-Ark 15K even reaches the 26A limit sometimes, so performance has been pretty good.
Things would normally look like this, e.g. on Sept 14:
M1 would sometimes get the bump to 200V+ a bit later than M2, e.g. on Sept 18:
All of a sudden, this is happening. It started happening on Sept 21, this graph is Sept 30:
Notice how M1 shows ~50V during the night, and the voltage kicks in much later during the day. Current stays at 0 until everything kicks in. However, once it does, it behaves pretty much exactly the same as M2 until the Sun sets. This has happened every day since.
Another example, on Oct 1:
Has anyone seen this before? I've contacted the installers to take a look. They acknowledged me, but we haven't set up an appointment yet. I haven't contacted Sol-Ark yet. I wanted to share here to see if anyone has seen this before and might have any helpful information or ideas of what could be causing this.
Thanks!
Thanks!
