I have some more questions for other 15K users.. hope this is the correct forum, if not, please let me know.
1.0 How do you adjust the Battery SOC on the Sol-Ark. Currently it is saying 80%, but the JK BMS is saying 70%. (48v 16cell 280ah home built battery)
1.1 Update.. the Battery BMS is now saying 100%, and that agrees with the Sol-ark. So it appears to be in synch, not an issue.
2.0 I am not seeing any PV power numbers on the main screen for my AC coupled solar power, I do see the home load, and the battery usage, and it appears that the AC coupled Solar power is just being added to the home load. So I see 4000W going into the load, and 500W coming from the grid, I can do the math and discover that the AC coupled array is delivering 3500W (Zero from battery).. but the little Solar Icon is not showing the AC coupled to grid pin Solar power as a stand alone live feed. Is that a set up problem or is the Solar Icon on the main display only used for DC PV input?
Update: The little cool Icon with the arrows doesn't appear to work for AC coupled PV input, however in small letters at the very top of the main screen it does report "solar KWH generated today" and that number agrees with the Enphase app number so I can live with that. I just have to do some math to understand real time results and subtract the grid input from the Load, and the difference is the AC coupled PV.
3.0 The "more" option buried on the WWW interface under the inverter has a nice graph that shows all the different power flows, so I can see battery SOC, Grid and loads all on one line graph, but again, the AC coupled solar PV is not shown as a stand alone item there.
4.0 Does anyone have a setup that ensures zero power sent from the AC coupled solar to the grid? Yesterday I pulled the main disconnect as my setup was sending power to the grid, and since I am not yet approved, I don't want to do that. I guess I can just turn off the main cut off switch each morning and operate off grid, but it would be nice if the Sol-ark could control that for me.
5.0 When I ran yesterday completely off grid all of my home equipment operated including my 3.5 ton heat pump. I see recommendations for install of a "soft start" but if the Sol-ark can handle the locked rotor starting load, why do I need that extra expense?
6.0 Talking to an HVAC expert he explained that only when you try to start , then restart immediately the heat pump compressor is the inrush current highest. If you wait 5 minutes or so between HVAC starts the high and low side pressures slowly equalize and the inrush current required to start the compressor is much lower. He also said most home thermostats have a delay built in for that purpose. So that is another reason why I am not sure I need to worry about a $350 AC soft start setup/expense.
7.0 Yesterday I modified the AC coupled setup to turn off the array when battery hits 90%, then turn it back on when it hits 77%. The shutdown worked, but when it restarted many of the Enphase micro inverters had "errors" and the restart was not clean. I sent an email to Sol-ark about that issue, and opened a trouble ticket with Enphase as well. Overnight Enphase updated firmware on my inverters and my combiner box, and said it appeared to be operating normally. Problem is the enphase array app showed green and normal, and until I drilled down to the "details" option and showed status of each inverter, I did not see the errors. And of course there was no error code indicating what the error was, just the word error. The gen pins on the Sol-ark did have 250V so that should have told the enphase grid was up, and you should operate.
7.1 Today I am "on grid" and the battery is now fully charged to 100% , but the Sol-ark is not turning off the AC coupled array, so I guess my understanding of the On/Off feature based on battery level is for "off grid operation only?" Assume that is the case, please correct me if I got that wrong.. assume if on grid, the Sol-ark will just let the PV run to support loads, and backfill with the grid which is what it is doing now.
7.2 Confirmed from Manual, and my operation, the AC coupled PV off/on feature only works when "off grid" Today I was out in the AM, and when I came home battery was 100%, and 8KW of PV from the AC coupled PV was going to the grid. No other settings appear to matter, so I had to pull my main disconnect to stop sending power to grid.
8.0 When operating entire home "off grid" yesterday several of my LED lamps were "Flickering" one large one in the basement closet where the Sol-ark is installed was annoying. Any suggestions on what causes that, and any corrective actions I can take?
9.0 Yesterday in my off grid test, the inverter reported "offline" several times, can anyone explain why it would go "offline" meaning I cannot access it from the WWW link.
Sorry for so many questions, and thanks to all who share here, I really like the forum and the suggestions others made (IE how to set up the AC coupled on and off vs battery level explanation was very helpful. As I learn things about how it operates I will update these questions so the results and questions will all be in one place for others.
