Hello All..so I have my first 280Ah 16 cell home built battery installed, and have set up time of use to use battery when sun goes down. Others have pointed out that the SOC on the Sol-Ark is not very good. Last evening my Sol-ark reported an instant drop from 45% to 0%, and I investigated what was up. Goal is to have the SOC on the Sol-ark disconnect from the battery, FIRST, then wait until sun comes up and recharge. This setup is recommended by Sol-ark. problem is when the Sol-Ark thought the battery was at 45% SOC, it was actually very nearly dead (based on the voltage log below).
The JK BMS is set to disable discharge whenever it sees <47V. So in this case the BMS shut down the battery discharge, and when that represents 0% SOC.
When I compare current SOC, as the battery is charging up, the Sol-ark is reporting 18% and the JK BMS is also reporting 18%. Prior comparisons showed differences where the Sol-ark reports 65% , and the JK BMS reported 45% so the Sol-Ark appears to be reporting a higher SOC in general, but to go from 45% to 0% when the battery is near dead is pretty awful.
This event was triggered by 4 days of crappy cloudy weather where my single battery never got about about 55-65% SOC.
Goal is to have Sol-ark disable discharge when it sees 20% SOC (that is programmed into Sol-Ark) and battery empty is also programmed at 47V.
If the battery is empty, and Sol-ark thinks it is still at 45% SOC, then the BMS cut-off is hit, that is not what I need/want.
Suggestions? Switch SOC to V instead of %? Other parameters to set?
Attached below are the Sol-ark SOC, and V charts for the event described.
Thanks in advance for any suggestions.
