I called and talked to a Tech at Digikey today.
They don't sell this relay but he looked up this Datasheet online. He read the Header and said it's a 200A Relay what's the problem. I asked him to verify, and like me he headed straight down to the Graph and said well it's 200+ Amps at 30K cycles.
I said look up at the Top at the 50 Amps and he looked at it and said it seemed odd that they would put 50A and then show 200A on the Graph. He then pointed out that it is a 200A rated relay and that those ratings are NEVER based on the contacts just being closed.
I agreed and said it's still kind of puzzling.
He looked at it for a bit and then said look at the Contact Data and pointed me to this.
He said well that pretty much lines up with the Graph and I have no clue why they printed 50A for Make and Break but we don't rate relays at capacity they can Carry when they are just closed. They are rated for switching current and voltage.
He pretty much cut it short and asked if he could help with anything else.
Anyone can call DigiKey and ask the same question.
Dial 1-800-344-4539 and Select Option #1
You will get an operator and just ask her to connect you to a Technician who deals with Parts Specifications.
I was on hold for less than 6 minutes.
Please let us know if you get a different answer.
