interesting... My 15k is still sitting in its box, but the permits should be in in the next few business days and then we can start getting it up and running... I only currently have 11.5 kw of solar panels up on the ground stand, currently hooked up to nothing but wind (cables are hanging), but i plan to add a second array to max out the inverter, if there is more overhead in there, maybe i will change the number of panels for the second array to a bit more, my current array will fill up MPPTs 1 and 2, but MPPT 3 is going to be empty until i get the second array setup, but getting the system running first is the priority, then i can putz around with the second array while im saving money on power already.
I know its not uncommon for companies to overspec their equipment, or de-rate it to leave a good safety margin, maybe they realized that margin was really big, and decided to open it up a little bit to the end user?
