bryanmccoy57
I am designing a 200Amp grid tied system using a single Sol-Ark 15 with two discover batteries and around 10Kw of solar. The Sol-ark grid input will be connected directly to the 200amp main service with no other loads. The 15k load terminals will be attached to a 300amp main lug panel for the home's loads. Assuming the 15k can combine grid power with inverter power to its output, could it the combine a full 200amps from the grid with 50amps inverter to produce 250Amps output? The home will occasionally require over 200amps.
