Settings look ok from what I can see. I would turn off the time of use crap until you get the rest of it figured out. Kinda a long shot, but I have seen this behavior when someone forgets to turn the inverter on, blue ring side button, for some reason the inverter will act and look like its on, and then randomly shut down and turn back on, but this was with grid power hooked up. Also looks like you have battery comms all wired up but dont have the BMS Lithium option checked on the battery page, and are using Voltage Control? I prefer to use voltage control, but having all the comms wired up could maybe be causing problems.
Do you not have monitoring setup on this system? That could help you troubleshoot a lot and figure out where power is coming from and going to.
Not trying to be a dick, but your battery wiring sucks, sorry, hard truth. This could end up causing a huge problem, melted terminals, batteries, or worse, a fire. Id be curious to see how its hooked up to the inverters. But it looks like one set of maybe 4/0 cables coming from the bank, when you have the potential of 4 battery input breakers between the two solarks. If this is the case, then your main cables are good for about 200A, and you have the solark set to charge at 275a, then with the tiny 6awg cables between batteries, you will be melting those things in a hurry if you charge much over 100a for very long. If you charge the bank with 275a for 10 minutes, those 6awg cables will get boiling hot, along with the terminals on the batteries. Im not sure on the solarks, with 2 of them, if it would output 275a total, or 275a each, if each, then you are in for some real trouble!!! Those 6awg jumbers are designed to hook up to a bus bar, not jump a pack of 10 batteries together, they are supposed to handle the current of ONE battery, not NINE other batteries down the line. Im guessing you probably have the inverters daisy chained together too. I would run a seperate feed from each inverter to the bank. The rest of your install looks nice, atleast from the outside!
More description of your system will always help.
Also, turn your TEMPCO setting to 0, for lithium batteries.
