Sol-Ark 15k Smart Load capabilities
fmemon
Michigan
I've been doing a little searching and have not been able to get a clear answer on the power output of the Generator line with the Smart Load setting turned on.
For my particular installation, I will be setting the the system with the "On Grid Always On" option turned on.
With regards to the physical installation, I am planning on connecting the Smart Load output to a subpanel, which will have my 2 A/C units connected to it. The intent to to turn off both units during a power outage.
My question is with regards to the on grid capability of that Smart Load output.
Can someone confirm if the Smart Load output has limited current output or if it shares up to the 200A coming in from the grid? In other words, if I have 200A service coming into my Sol-Ark 15k, can I feed 80A to the LOAD line and 80A to the GEN smart load output line?
I understand, I'll rarely, if ever be in that situation, but I'm trying to understand how the two outputs can work.
Thank you
Smart load has a 100 amp limit on the 15k.
Load has a 200 amp limit.
Grid has a 200 amp limit.
The 200 amps from the grid can be split up to the limit of the connection.
Reviving this thread again for a follow up question.
Since the smart load output for the SolArk 15k is limited to 100A, will there be any issues putting two whole home air conditioners on that particular output?
Nothing else will be placed on the output.
I've included the label from the side of the air conditioners on this post for reference.
I'm assuming the 100A is a continuous output and does not include any kind of surge capabilities.
Essentially, I want to ensure that the Sol-Ark won't trip if both air conditioners turn on at the same time. There is currently no soft starter installed on either of the compressors.
Thank you
