Update -
Sol-ark replaced my 15k. Unfortunately, we are still clipping at 13.4kw of DC PV. They are circling back to my arrays now and asking about combiners etc. problem with this is, while all 3 MPPTs are connected to my three arrays they max out at about 14.3 amps each. If I pull off any single one of the arrays and it doesn’t matter which one, the other two arrays will produce around 200amps.
I do feel like they want to fix it and maybe they will, but I’ve yet to see anyone I’ve spoken with show me a graph of where they are having three arrays each at 6,400 watts max connected to the 15k and showing it “inverting” a full 15k.
If you have screenshots of the 15k inverting a full 15kw of DC PV and grid connected with grid sell please post here. I keep hearing from Sol-ark that the inverter should clip/throttle a full 19.2kw 3 array setup at about 15.3kw. I’ve never seen it once. It hits 13.5 or so max of DCPV and just throttles.
Here’s my array info -
Array 1 - 400w QCELL G10+ (MPPT 1)
16 panels configured in two string of 8 in series. The two strings are paralleled and sent to the solark. Max 6.4kw
Array 2 - 400w QCELL G10+ (MPPT 2)
16 panels configured in two strings of 8 in series. The two strings are paralleled and sent to the solark. Max 6.4kw
Array 3 - 320w QCELL G5 (MPPT 3)
20 panels configured in two string of 10 in series. The two strings are paralleled and sent to the solark. Max 6.4kw
The below photo is todays production. You can clearly see this clipping.
