Cosmic Frog
I've seen some posts about the 15K with a generator but nothing that dumbs it down enough for me.
So, I'm looking at some generators around the $1000 price point.
My installer is telling me those are not compatible with the Sol Ark 15K.
They want to install some type of plug setup (additional panel on the wall) instead of hooking up directly to the Sol Ark.
I don't know if this is right or not. From the picture it shows 4 wires going from the gen to the Sol Ark. Seemed simple enough.
The manual says ONLY Supports 120/240V Split-Phase generators.
When I look for split phase generators I get a bunch of results for inverters but nothing that says I'm a split phase generator.
Can anyone please recommend a generator that will hook up directly?
I'm using this as an emergency backup in case the grid fails so hopefully never use.
I'd like to be able to store it and only hook it up if needed. Gasoline is fine but if it has additional options that is fine too.
Thanks.
Aaron
Thanks.
Aaron
