Trying to understand a bit the Sol-Ark pass through power specification (power from grid directly to the load via the inverter). I've marked the spec sheet in red below (8K-P model). 15kW @ 240V and 7.56kW @ 120V (each phase). That seems like a really nice feature so that an entire home can essentially use this smaller inverter and still power everything in the home like normal when the grid is up because 15kW in my case definitely covers the entire home even with electric oven & electric dryer. When the grid is down and the inverter is running from batteries or solar, then i have to be slightly more conscious to not exceed the 8KW @ 240V but that is a small compromise.
Questions:
1. What is the inverter efficiency on the pass-through power? Is it part of the normal CEC 96.5 (97.5% peak) efficiency? That would make sense because I believe the incoming grid AC still has to flow via the central DC bus on the inverter so it has to go through a AC--> DC --> AC conversion to get to the load.
2. Has anyone tested this in real live up to almost the full 15kW @ 240V AC load? I'm just skeptical because the inverter is only rated for 8kW @ 240V AC output in off grid mode which is 50% (roughly) as much.
Regards
Schwizer
Questions:
Regards
Schwizer
