Cheap 4-life
My body is 2.63 trillion volts, .07v per cell
I’m still confused I guess.. so with 4999w on one leg (one watt under the 5000w that would trip the inverter), the amount that the legs are unbalanced doesn’t matter? Meaning the other leg could have only a 1000w load while the other leg has a 4999w load? Your saying the 1600w only comes into play when one leg is at its max?... if one legs at its max then it will trip just due to that, regardless of the amount of load on the other leg.. so then the 1600w doesn’t exist?Yep it would do 4800W per leg but that is now up to 5Kw+ per leg after the update. If you pass that on any one of the Legs then yes it will trip. My house is typically consuming 2200-2500W all the time due to My Salt Water Aquarium and it's Lighting system, Pumps and Chiller plus the Houses 26Cu Fridge and misc other stuff.
For several hours per day the power may hit 6500W but that is only when the Water heater and 2x 12000BTU Split AC's are running. It is pretty darn hard to get up to 9KW. I have to add on the Dryer and washer plus Microwave to get to that number and it still wont trip because I made sure to balance my Panel box.
