First off, I’m building OFF-GRID.
This has been a sporadic problem, buy since we are now starting to use our system more to finish our build, the problems are just now showing up.
We installed our solar, 12K x 2 stacked, power house, well system, backup generator, etc before building our house.
Despite what people think of David POZ video and how he tripped Sol-Ark, please tell me why my Sol-Arks faults when I’m pulling no big load and only using a small Rigid hand held router, heat gun when making battery cables, portable band saw, corded drill? Faults are F-26 and F-41.
LED lighting is all that’s being used to work by until we use a device such those mentioned above that used power. Ive used other devices such as a 12” miter saw, drill press, 120v flux core welder, etc... with no faults.
Last week we had the Sheetrock guys out to hang and finish Sheetrock at our homesite. They were using a corded electric drill to mix the sheet rock mud to finish the sheet rock. I was not there to observe, but the electric drill tripped the Sol-Ark 4 times in about 2-hrs. My app shows all the faults!
My system was installed by Engineer775. So it was done by a professional.
Engineer775 says: “Okay so if you read the error code I don't think it is an unbalanced load if you read closely it says DC load on the AC output when off grid. That is what I believe is happening because of the green boards. The parallel system stop is always subsequent to this unbalanced load. So if the drywallers are mixing mud with a variable speed drill it is looking like a DC load to the inverters and shutting it down it is not an unbalanced load. Does that make sense?”
Apparently grid tied fixed or helps this issue, he said.
So with that being said, it appears you don’t need to overload one leg, to make Sol-Ark trip! At $7000.00 per inverter ($14,000.00) this is ridiculous!! I’ve reached out to Sol-Ark and they will only send out “their” transformer as a band-aid!! I wanted upgraded MCU or swap out blue boards but was told this isn’t possible. I then asked for replacement Sol-Arks and we’re not doing that either!!
Maybe I need to post a video like David POZ did to show Sol-Ark is not all it’s cracked up to be for the premium price!
Not to mention, for the last several weeks Sol-Ark has not started the generator when it needed to be started per preset limits! However a software update this week has seemingly fixed that?
So, any thoughts or input on my situation? Forgive me for being extremely angry here in my post, but hope you can imagine what it’s like to have these issues when you’re off grid. Paying for the best and get crappy results. To me a transformer, to fix a transformer-less inverter isn’t a satisfying response.
Edit: My bigger concerns are what else may trip Sol-Arks once we start living there? It’s a hassle and unnerving to not know how stable your only power source will be.
Never thought small items would do this either!
