In the winter, we found we can run almost nothing on solar mostly because of the parasitic load of the equipment combined with poor production. I knew the production was going to be bad but I didn't know the batteries were going to use so much power. It's been a hard pill to swallow. I would have chosen different equipment if I had known. But it is what it is for now. Right now, we can stay off grid with the entire house and we only get down to around 50% on the batteries. I couldn't even use all of the solar production we've been generating this week. Our high was 67kW in production the other day and I had a hard time trying to use enough to see such high numbers. I was running my washing machine, my dryer, my air conditioning, a second air conditioner, the electric oven, the stovetop and I was thinking about running a vacuum too as it was the only other appliance I hadn't turned on. We didn't trip the system at all when all of this was running. It's been mild weather so nothing's running too hard. We do have a lot of refrigeration which may prove a bit hard in the evening when production is low but temps are still high. We'll see some much higher temps this weekend which will be interesting to see how the system performs. This is our first year having the system up at all and, mostly, we've been using the grid for everything while we work out the kinks. We are definitely adding more panels. I'm hoping to get enough to cover the parasitic load so we can actually keep the water and a couple of freezers running off the system in the winter months without having to revert to other power sources. The bank is too large for winter but may be too small for summer. We're in a weird spot, for sure.
