RV Adventure Couple
- Apr 3, 2020
- 51
Are you going to mount a wind turbine on your RV?So they wont back feed each other if one is producing less?
I ordered the tesup master 940 and I am going to make my own tower when it arrives mounted to the bumper, midway up the rv, and roof.Are you going to mount a wind turbine on your RV?
What wind turbine and tower do you have?
Yea I would think it would be common sense to not drive with it deployed. It's a little late because the turbine will already be arriving in a few days. If it doesn't live up to its worth I will just sell it and put more solar on my RV.Just don't drive with it deployed... and...
Do your research on wind. It RARELY is worth the effort:
The Truth About Small Wind Turbines – Solacity Inc.
Installing a small wind turbine? Get the information you need for an informed decision: The good and the bad, just the literal truth to help you choose.www.solacity.com
Our off grid compound is in an area with 10-12mph average annual wind, but it's very erratic, and it's often NOT blowing at night.
On average, I'll be lucky to get 80-100 Watts at all time.
And I'm going to pay about $2500 for that. Why? Sometimes, I don't get much sun, and it tends to be windy on those days.
Many are misled by the power rating of the turbine. All that is just the rating of the generator. To get that 400W, 1000W, whatever, you're talking about winds you don't want to be out in. A 6' diameter 1600W wind turbine is going to need 90mph winds to collect that much power.
Lastly, wind turbines need clean air flow. They typically need to be about 20-30' above any nearby structures/trees/RVs, etc.
If you're looking to have a fun project where the reward is a job well done, but the results are disappointing, then go for it.
Yea I agree, we were in Utah alot this past year in the RV and nearly everyday got wind that was good enough to produce power. I obviously am not banking on it being my main source of power, but a supplement and cool project / youtube video.Sorry... meant to put a after that bit.
Kudos to Tesup. Don't always see this published:
About 99W @ 6m/s (13mph).
And an illustration of the need for having the turbine well above the influences of obstacles:
Pretty common for my area to have 9m/s sustained for several hours per day. Using that graph, that's 313W. That will be nice. Looking at the 10 day, Monday is going to have 12 hours of 6m/s+ with a peak at 10. 8 of those hours will be after solar charging drops to zero, so on days like that, I'll LOVE it, but for the next 3 days, mostly 3m/s or under.
It really comes down to being okay with a bipolar relationship with your wind turbine... you either hate it or love it - depending on which way (or how much) the wind blows...
First off understand I am not arguing any of your points as they are factually correct.Just don't drive with it deployed... and...
Where in the PNW are you located? Im thinking about adding a turbine that I got to my existing system because why not. Living in east Portland there is always some sort of breezeFirst off understand I am not arguing any of your points as they are factually correct.
I do however wish to add this thought. With low maintenance for wind turbines and the fact that any time the wind is blowing they are making power makes them a perfect addition to your solar setup. When examining power output to solar; wind is a total loser that sits in the corner doing very little. But it is always doing very little. This IMO makes it totally worth it. The power gained back at night alone most likely will offset any losses in solar for the day. Especially on those windy days with no sun like we get here in the PNW.
In short. Is wind worth it? Probably not. Not in the short haul for sure. But over time, it pays for itself over and over and over. And adds a few extra watts at night whilst you are sleeping. IMO.
