I am planning on almost 500 watts solar(48v) Possible 95 volts with these amorphous panels. at 15amps feeding an MPPT. I have not bought the MPPT yet. I also will be feeding 48v volts from a 400 watt turbine. I am not sure what it will do power-wise, 400watts, likely 200watts Through a Schneider c-40. I plan on using this as a diverter to heat water. My question is if they both are connected to the battery will the excess power go through the c-40 diverter? I'm guessing the MPPT will use what it needs. Would the MPPT just put out more voltage if the batteries needed it? It doesn't divert like the c-40. I wouldn't mind any advice since I'm not really experienced with this. This will be feeding my BYD batteries set up as 48volts.
