chamberwil
Yes I did. Why it’s it a good idea? Doesn’t it clean and prevent future rust?Are you saying you put WD40 on the electrical terminals themselves? Not a good idea.
You need to remove all the residue after applying; the company makes a specific version for electrical contacts but even that gets mixed reviews.Yes I did. Why it’s it a good idea? Doesn’t it clean and prevent future rust?
Get the "Solar Tilt" app on your phone. Great app for free. Has a built in tilt gauge. and will give you all tilt info for your location and anywhere on earth for today or any day of the year.Use a pv orientation/inclination tool to help get the best angle for your location. It varies from month to month as the sun changes its position in the sky, but if you are close to optimal it definitely helps. My optimal yearly inclination is 28.2 degrees.
Thanks for this. For my location it recommended 15 degrees. My panels are at 13-14 degrees, so I am on point. Is 9 in the morning so I am monitoring the PV output. It a little cloud but fingers crosse.Get the "Solar Tilt" app on your phone. Great app for free. Has a built in tilt gauge. and will give you all tilt info for your location and anywhere on earth for today or any day of the year.
Wow!I'm not expert but why do you have the panels just about laying flat? Also looks like alot of shading on them. My 1360watt array drops alot also when there is shading. I can walk in front of it and drop the watt output. LOL
I used https://pvwatts.nrel.gov/ to get the ideal tilt for my off grid array which playing with PV Watts it was 30 Deg for max production for the year. Even though I will not have them system on 24/7 matter of fact I can put the array up and take the EcoFlow home with me.
I made my array so I can tilt it just for fun and testing. A friend of mine likes to play and use the paint can trick and try to get every watt of of it when we meet up at my property.
I posted this before but here is my setup. 4 340 Watt Used panels. EcoFlow is limited to 60V and 1000watts in two seperate inputs. So these panels are two separate arrays connected in parallel. These panels are 41VOC so I can't connect in series.
The Ecoflow will be in the cabin later this is still work in progress.
I know I need to start a separate thread on all my solar toys I play with.
Are the 4 panels still wired in series? If so, you should be closer to 80 volts, not 40Update.. I am getting peak sun not shading these two pictures will show what going on.
You are right I am closer to the equator. Yes, the panels are in series. At this time i am experiencing a passing shower so when the rain pass I would try each panel individually to see what I get on each. Here is a battRey voltage guide I got when I switched to 24v.For everyone saying the angle is wrong, "too flat"
Read the first post, he's at the equator, the sun is nearly directly overhead 1/2 the year. They're fine.
Something isn't right there. Try what has been suggested, test each panel individually or in groups to see if you've got any duds.
Edit: also, what are your battery voltage settings. I don't run @24 volts, so don't know the numbers off the top of my head, but 27 volts seems pretty full. Once the battery is full the charge controller will limit output to not overcharge the battery.
Yes they are all factory installed. I even wired the PV connection directly to the charge controller to rule out the breaker same result. Any one running panels on a 24v system, let me know if this is normal.Are all connectors factory installed? Correct polarity is absolutely critical in dc, pv wiring. If all connections aren't as they came from the factory you may have one panel cancelling out another.
I actually do have some other panels and a small charge controller. I had them running for the day to supplement my power and it running slightly better now because of the position of the sun and the fact that one is being shaded now. Earlier it was out performed by its big brother.I definitely do not think this is normal. To me there might be a connection issue. Panel wiring. charge controller damaged. solar panel damaged.
Any chance you can try some different panels? try a different charge controller?
how close are the panels to the charge controller?
My suggestion is to try the other solar panels on the victron charge controller.I actually do have some other panels and a small charge controller. I had them running for the day to supplement my power and it running slightly better now because of the position of the sun and the fact that one is being shaded now. Earlier it was out performed by its big brother.
Might be the mppt finding the voltage that produces the most watts.So here is the update, the panels are operating correctly. The voltage at the panels is between 80 and 95V in the sun. And the voltage inside is 37v. So the issue is my wire. I am going to run a temp wire to see what I get. I am wondering if my mc4 connection is bad. Will update you guys in a few.
UPDATE: ran new wire and got the same results as before. Rule out the wire which is a BougeRV 70 Feet 10AWG Solar Extension Cable. The voltage is high as it should be when the when the charge controller is off. Once I switch the charge controller on the voltage drops to 37-40v. Any idea. ?
Quite possibly the case ?Might be the mppt finding the voltage that produces the most watts.
You might be into something here. Because my peak voltage when I was on 12v 3 weeks ago I was getting higher voltages.Might be the mppt finding the voltage that produces the most watts.
it still looks like you are only getting 350 watts max. is this an improvement?You might be into something here. Because my peak voltage when I was on 12v 3 weeks ago I was getting higher voltages.
I am really thinking that it’s because it’s using 24v.
Don't be jealous lolWow!
That IS the best thread hijack I think I've ever seen.
Congratulations.
