I have a question about grounding my panels. I think I read somewhere that my grounding wire couldn't be layed out too closely to itself. Reference the attached sketch. Can I start close to the pole, run the ground wire along top rail of 2 panels, up to the the bottom rail of the 4 top panels, back down to the top rail of the remaining 2 panels, then down to the ground to my copper grounding rod? My intent is to drive a grounding rod for each mount. The two mounting poles are 24' apart. The poles are sunk 10' deep and surrounded by concrete. The inverter is about 150' away and will get it's own grounding rod. I'm using IronRidge grounding clips on the panel frames.
