doityourself2021
Never Give Up - Ever
Hi Marionw - all good info. However for my Growatt SPF which only communicates rs485 , and the battery BMS boards are Seplos, three rj45 ports, CAN/rs232,and 2 rs485 ports, as per SA Battery info.. had to change BMS board Pack 1-3 dip sw..accordingly and us a USB-A to rs485 converter to connect to #1 BMS battery Pack.. Bingo, now all three batteries are being shown on the SA interface -SA needs to connect to some port on your battery bank that allows it to see all batteries so it can report on each individual battery.
SA also needs a connection to the inverter to report on inverter stuff.
If the only connection is to the Inverter, then the Inverter, assuming you have a closed loop communication with a "Master BMS" in your battery bank will report what the "Master BMS" is reporting to the inverter, that is all batteries in the bank as one big battery.
In "closed loop" communication the "Master BMS/Battery" will report to the inverter what it (the master) compiles as all the individual batteries in such a manner that the Inverter is seeing the battery bank as "One Big Battery". The "Master BMS/Battery" does not report the data for each individual battery to the inverter
If you have an RS232 port on the batteries then your probably need to connect the RS232 port on the "Master Battery" to SA using the appropriate RS232 (or RS232-TTL) to USB Converter.
SA, with a connection the inverter and another to the "Master Battery/BMS" will then display the Inverter data as well as each battery in your battery bank
