wattmatters
Solar Wizard
lolOn a side note, since your battery is 100% and you are showing no PV, turn something on for no reason. ?
It's early morning and pissing down with rain, that's all the PV can supply.
My batteries are sealed lead acid (380 Ah / 48 V) so even with zero load they'll always accept some charge if available, even if it's a small 1 A float charge which is roughly 50 W of PV. Add the inverter's self consumption (set 45 W) which means the PV will always have a minimum demand of ~100 W. If it's providing less than that, then as Scotty says, "that's all they've got Jum".
