I have Solar Assistant working fine and it is publishing mqtt messages, confirmed with MQTT explorer.
But using the documentation on Solar Assistant to set up Home Assistant seems to be no longer valid. Likely the integration needs to happen slightly differently now. It seems that Home Assistant is getting messages because the "Start Listening" seems to show messages coming into the Mosquitto broker. Also in the devices page under MQQT, I can see Luxpower SNA by Luxpower which I assume means my 6000XP is being recognized.
What isn't working is the next step to set up the Energy dashboard? Adding consumption, adding my solar panels seems to be not working. The setup screens say it cannot find any statistics when I try and setup following the guide on the Solar Assistant page. Where is the best place to get help with getting Home Assistant integrated with Solar Assistant?
