Richw68
I am setting the Grid Sell Back Power(kW) with solar assistant on the FlexBoss21 inverter.
The problem is Solar Assistant is setting this value as a percentage and not a value as the FlexBoss wants. Interestingly enough if I use 100% in Solar asst it sets the value to 10. In fact with the FlexBoss 21 the max is 12 from what I have researched. Has anyone ran into this? I have also sent an email to Solar asst as well and I am waiting on a response.
Below is the corresponding setting in the eg4 monitor.
The end goal. I am in self consumption mode and using PV to power loads, charge batteries and then sell back. I don't want to sell back any power until my batteries have been charged. The problem is in self consumption mode and sell back enabled the inverter power loads, charges batteries. In the addition though it seems to split the power between charging the batteries and selling back. Spoke with eg4 support and this is the designed behavior. Given that I setup a Solar Asst automation to set the value once the SOC has reached 95%. The issue is I cannot set it to 12. Only 10 since it is using a percentage.
Thanks,
Rich
Thanks,
Rich
