I have twin MPP LV 6548 in split phase and a Daly 300 amp bms. The inverters and bms are connected and working ok to the SA. I was wondering what are the references of the high and low numbers that the Solar Assistant uses for state of charge. Is it the inverter’s bulk charge voltage value for the high? For the low is it the back to utility or the Low DC cut-off voltage? Or is it using the bms data?
