Lt.Dan
Solar Wizard
I do enjoy the Argon M.2 case, which uses an M.2 SSD. Makes the Pi so much faster too!
Never thought about that because the data just isn’t that critical to me and SD cards are cheap.using a ssd as boot and storage for my pi..
will outlive the pi, and wont corrupt
You can learn a lot by looking at the monthly trends.I have not had my DB corrupted yet.
Probably hurt my feelings but I take the macro numbers and keep them in excel so If I lose the DB I still have archive data just not the minutiae I had before.
It’s nice to have but it’s not integral to my operating.
I am well aware of it and that is why I open every device I have like TV's, Laptops and remotes and remove the camera connection as well as clip a wire on any Mics that are built into remotes and Laptops. I guess they can still use those accelerometers as Mics to pick up audio. Some of this crap came back to bite me when the wife needed to do some Zoom Medical CE courses during Covid. Had to connect some stuff back. All of this is kind of pointless if you have a smart phone in the house but it's the whole MS, Google and Alexa stuff I am trying to get away from.You would be surprised at how Mary IOT devices call home and they are not all here.
Yep! I bought three Chinese camera system from Amazon to monitor the Interior of my electrical room.My Hickvision cameras where calling Home to China on an hourly basis.
Yes as explained above I am very aware of what smart TV's etc transmit. So does any remote with Alexa or Google built in. The problem is that your phone is also doing the same thing and there is no way to conveniently turn that off.I didn’t bother to capture the data to see what it was but just blocked it.
You would be very surprised at the amount of info a Smart TVs / Thermostat Ect, sends out to different folks.
Frankly it’s none of their business so everything not specifically allowed is blocked.
Actually with Firewalla you see every network flow from every device.You can learn a lot by looking at the monthly trends.
All three required me to sign into an App with my precise GPS info turned on. If it was not on I could not log in.
I let the first one have the info and then noticed on my router that data was going out on intervals. It seems to transmit every 30 minutes or so.
I use Tomato software on my Router so it's pretty easy to see that something is going on.
Anyway returned that Camera and got another one, it had the same issue so returned it and then the third one the same thing. I ended up buying a closed loop RF based system with a 5" screen.
I am pretty sure they get it one way or the other. Either it is stored on the smartphone until you get into 4G or 5G land or they can use the 4G-5G even when you think it is off or on WiFi only.I see your point though because as soon as you go outside your network with your phone they get it anyway.
Fortunately or Unfortunately I live in the middle of nowhere.I am pretty sure they get it one way or the other. Either it is stored on the smartphone until you get into 4G or 5G land or they can use the 4G-5G even when you think it is off or on WiFi only.
If your going to go as far as to make a turned off phone not really be off, then it would make sense you cover all the other bases as well.
speeds up your pi a bunch, no corruption, and had a bunch of intel enterprise ssd's laying around doing nothingNever thought about that because the data just isn’t that critical to me and SD cards are cheap.
I assume as long as the drive is formatted to FAT16 or 32 it would work.
Probably be better for multiple Storage writes also..
Nice.. I think I have a 240 GB sata 3 to USB external SSD laying about from some project.speeds up your pi a bunch, no corruption, and had a bunch of intel enterprise ssd's laying around doing nothing
I think there is something about SA licensing that is stuck with the original SD card you provided, and transferring it isnt very easy.Nice.. I think I have a 240 GB sata 3 to USB external SSD laying about from some project.
Might just format that and use Etcher to transfer SA over to it to see what happens.
I didn’t think the PI had anything like a TPM chip in it but it looks like they provided a way to move it regardless.I think there is something about SA licensing that is stuck with the original SD card you provided, and transferring it isnt very easy.
EDIT: Nevermind, looks like that isnt the case anymore. https://solar-assistant.io/help/general/transfer-license
Yes, this would be my 1st choice, however the RS485 port is being used to control/monitor 6 x eFlex batteries and its not clear if both can be on the same RS485 bus at the same time.I use the CANBUS/485 output on the inverter board
No you cannot use the Port for both with the eFlex.Yes, this would be my 1st choice, however the RS485 port is being used to control/monitor 6 x eFlex batteries and its not clear if both can be on the same RS485 bus at the same time.
@HighTechLab Can you confirm what port the SOK uses? I'm contemplating getting SOK's in the future for the SA 12k I got from you, but also want Solar AssitantIf you are using a battery that is not supported by the Sol-Ark like an EG4 or SOK that do not have supporting subroutines built into the Sol-Ark then the address remains at 00 and I suspect that both the battery and Solar Assistant can work on the port with a Y adapter (splitter) cable. In the case of the SOK I think it uses the Canbus port so that would make it even easier.
I just checked and it's 00 and uses Canbus so all you need is a Y splitter cable like the one below and the cables for the SOK and SA to plug into it.@HighTechLab Can you confirm what port the SOK uses? I'm contemplating getting SOK's in the future for the SA 12k I got from you, but also want Solar Assitant
SOK-Sol-Ark comms use CAN.@HighTechLab Can you confirm what port the SOK uses? I'm contemplating getting SOK's in the future for the SA 12k I got from you, but also want Solar Assitant
Wouldn't that be going a step backward since the Sol-Ark would no longer be receiving real time battery info from the Sol-Ark.SOK-Sol-Ark comms use CAN.
I believe most SOK users though, are using the USB-RS232 cable and going from the battery straight to the solar assistant PI.
We actually got an email from SolarAssistant, because we have been working on implementation with the SOK as well as documentation. Once I figure out this SMA communication headache, Solar assistant will be back on the front burner.
I agree, I want the inverter to know what's going on. Unless Solar Assistant can be the middle man, and the Pi will give all the info to the SolArk? That would be pretty sweetWouldn't that be going a step backward since the Sol-Ark would no longer be receiving real time battery info from the Sol-Ark.
I am not sure either but I am much more confident that since the SOK uses the Canbus port and SA uses RS485 port they should both work together and the Sol-Ark will communicate the battery status to SA as well as Powerview.Disclaimer: I've never used solar assistant on a sol-ark, so my knowledge with the Sol-Ark integration is limited!
Perhaps I am mistaken, but I believe solar assistant can monitor what is going on with the inverter and the battery independently, at the same time. So the battery and inverter communicate to each other for operations purposes, and solar assistant pulls data from each independently...I think? Maybe I'm off a mile here, like I said I haven't fully dug into this yet.
