thanksYes I have 2 Deye in parallel with 2 USB cables to the SA working great.
Do you have to view the information separately?Yes I have 2 Deye in parallel with 2 USB cables to the SA working great.
thats why I only ordered 1 wire but SA only seems to have the 1 inverter, how do I get it to see the other ?for your mpp 1 cable should be sufficient ( it is for mine)
Parallel Axpert inverters with Pylontech | SolarAssistant
See an example of how SolarAssistant is used to monitor parallel Axpert inverters with a Pylontech battery bank.solar-assistant.io
"The standard USB cable that came with the inverter is used. SolarAssistant can read both inverters through a single cable plugged into one inverter."
It show the combined values in the graphs and can see independent inverters productions.Do you have to view the information separately?
Or Does it combine the information, as a single plant?
are you sure the paralelling is setup correctly ?thats why I only ordered 1 wire but SA only seems to have the 1 inverter, how do I get it to see the other ?
solar assistantWhat is S.A.
yes, I believ so, Im 2p1 on first and 2p2 and 180 degrees on other, and get 120 and 240 at the ac panelare you sure the paralelling is setup correctly ?
should be good.yes, I believ so, Im 2p1 on first and 2p2 and 180 degrees on other, and get 120 and 240 at the ac panel
Texican, did you ever get your 2nd inverter to show up? I have the same setup, and while I can see links for both inverters under the graphs, all of the values for inverter 2 are zero.yes, I believ so, Im 2p1 on first and 2p2 and 180 degrees on other, and get 120 and 240 at the ac panel
I am using 2 of the comm cables, one to each inverter and then both to the raspberry. are you using 1 or 2 cables ?Texican, did you ever get your 2nd inverter to show up? I have the same setup, and while I can see links for both inverters under the graphs, all of the values for inverter 2 are zero.
