Solar Assistant with Two 18 KPV
bgreet
Houston, TX
I just set up solar assistant and while both my inverters are listed in the settings, I'm only getting the information for one inverter. I thought it was supposed to be able to import data for both? Any thoughts? Right now, I only get the 3 strings from my one inverter and nothing from the second. When clicking on inverter in the dashboard it only shows the one. Thanks!
Also, the same is true in Home Assistant using MQTT. Only getting data from the one inverter and not the second. Going into the configuration, inverter 1 is the only selectable. Can go and disconnect and connect to the second manually though
Did you check if your WiFi connection is still active on the missing inverter?
How should I do that? Both are listed
Actually somehow I can now select them both in the message mobile app. Thanks you guys!
And I have been in and out of selecting different battery banks and somewhere along the lines it decided to only select the master inverter when I saved again, so always double check.
