I have 2 240 watt panels going to a charge controller charging a 100 ah lithium iron phosphate battery 100% charge I’m the controller shows 65 volts coming in but not any amps is this correct if not what to check
If your battery is full it needs no more energy therefore you will not show any amps any the voltage of your panels will go to open circuit levels. If you put a load on your battery until the charger kicks in again the the voltage of your panels will drop and you will start drawing amps again.
