Opening the touch safe fuse holders under load could cause an arc and fire.
If the DC breaker is garbage the same could happen.
Use an IMO disconnect thats designed to operate thousands of times under load, and handles positive and negative, assuming you have a single string or dual strings. Once you start paralleling three or more strings you need to have some kind of ocp.
