Xtinabritannica
- Jun 3, 2022
- 8
Does anyone see any issues with this design? (See image) The fuses and DC Switch are not in the picture to make it easier to read for this thread.
The idea is to use the A/C Out from the EG4 Off-Grid Inverter and connect it straight to the 120VAC Shoreline IN on the existing circuit board/breakers.
SPECS/Info:
Thoughts? Am I nuts?
Also, can we keep the 12V 27DC Marine Battery for backup?
TIA. I've learned solar from scratch starting less than 2 months ago, so I hope I have the right idea <3
SPECS/Info:
- 32ft Keystone 2003 Travel Trailer (will be stationary for a while)
- Parallax 7300 120VAC -> 12V Converter already installed with circuit board
- EG4-LifePower4 Lithium Battery | 48V 100AH
- EG4 3kW Off-Grid Inverter | 3000EHV-48 | 3000W Output | 5000W PV Input | 500 VOC Input
- 3x 345W SunPower in PARALLEL
- Rated Voltage (Vmpp) 57.3 V
- Rated Current (Impp) 6.02 A
- Open-Circuit Voltage (Voc) 68.2 V
- Keep the 12v 27DC Marine Battery??
