So I have 10k worth of 315watt solar world panels with a 10k solar edge inverter (SE10000A-US) with enhancers. It is not a HD one. I live in Florida and have lost power for weeks several times with hurricanes. I really want to get some system to keep running if I lose power. My goal it to have a system with a reasonably small battery backup to buffer the existing system. I am fine with primarily grid tie. But if we lose power to have the backup system able to work. I have a 100 ah 48v system on the way. I need a reasonably good inverter to keep the solar edge working. I would be ok to put a voltage sensing automatic transfer switch to protect the grid. I am not worried about everything working all the time. Just to help during the day when I have good production. My daily production is anywhere from 15 kw on a bad day to average over 45kw as high as 65kw on cold day in March. My normal usage is about 60kw. But could easily be under 40kw in an emergency. My peak loads are a well and 2 2.5 kw ac units. I have powered one ac compressor and both fans with a 5kw regular generator. That with the fridge and lights. I see lots of things about needing major battery banks and inverters as big as my current solar edge.?. I do not want to get a new solar edge HD to shed voltage. Is there anything that might work? I was hoping to stay in the $1500 range but at this point ready to go to $2500 or maybe more. I do want to upgrade batteries as I go but for now needs to stay with the 100 ah pack. MPP solar seems to have some good things but none specifically say ac coupling? It has to be at least 220vac and be able to get rid of excess at the peak of the day. My peaks is typically at or below 7 kw with the PV. Please help!
