Thank you in advance for your help. I have been watching videos and reading websites but I really have no idea what I am doing.
I want to build a solar system that I could use charge my Ford CMAX Energi hybrid car (7.6 kWh) and run a well pump (unfortunately, they are on opposite sides of the house), so I will probably put it on a trolley to take it to the car to charge (after disconnecting from panel). I might want to move it to a boat or cabin, when I retire, so I would like it to be marine grade.
I was looking at getting:
* A Renogy 300w 24 volt mono crystalline solar panel,
* A Battle Born 50 Ah 24 v LiFePO4 Deep Cycle battery, and
* MPP Solar LV2424 hybrid interverter (2.4 kw, 24v, 110/120VAC, 80A/2Kw, 60A utility charger).
I already have wire (600 volts).
Will this work? Do I need anything else? Suggestions?
