Is it better to have multiple solar panels in series to raise the voltage going into the bluette 200p
So that’s roughly 10A aka nominal. So three in series would be 1000W 10A+/- 93V nominalLongi 310 watt. 31 volt oc
Thanks. I will go that way. The bluette says it will take 700 watts max. Will the extra wattage generated by the panels gobto running my cabinSo that’s roughly 10A aka nominal. So three in series would be 1000W 10A+/- 93V nominal
Without going down the other three rabbit holes that should work based on the information in the thread.
That would make 122ish volts and some calculations should be done to come up with the max volts output at low tempsDo you have a link to those Longi panels? The ones that I found have a VOC of 40.3v.
Not really. 700W max is the max. The overpaneling will just increase potential on dismal cloudy days or give at tad more potential at sunup and sundown.Will the extra wattage generated by the panels gobto running my cabin
I think that any over voltage can go through the inverter and be used off of the plugs. Think the 700W is limited to what the battery can be charged at.Not really. 700W max is the max. The overpaneling will just increase potential on dismal cloudy days or give at tad more potential at sunup and sundown.
No. Watts isn’t over voltageI think that any over voltage can go through the inverter and be used off of the plugs. Think the 700W is limited to what the battery can be charged at.
