Like others here have done, I wanted to share my solar hot water heater I installed in 2007. There's 4 zones(domestic hot water Tank1, domestic hot water Tank2, House, Garage), each with a standard zone valve. And 2 pumps. One pump for the house, tank1 and tank2 and one pump for the garage.
A custom made arduino based controller runs it.
Each tank is a standard off the shelf 'indirect fired' 60 gallon stainless steel tank with built in heat exchanger. These were made to be used as a zone off a gas or oil fired boiler. Non toxic antifreeze is used in the hot loop to the evacuated glass tube collectors and then to each zone.
The controller brings the tanks up to temp first. Then the house gets heated or the garage depending on season and needs. The controller is hooked into the house thermostat so they talk to each other.
To heat the house a standard hot water radiator was used in the air handler.
To heat the garage the antifreeze is pumped thru pex tubing in the insulated concrete slab. Although rarely is there enough energy to heat the garage as it's last on the priority list. The garage is the dump load during the non-heating summer months.
This thing has worked flawlessly for 15 years. Those evacuated glass tubes work very well in the winter.
