ianganderton
Auckland, NZ
Yes I think that’s the plan. I need to do some comparisons first though to check to see if that theory will workCan use the NASA API to get the flat insolation with weather and then use the tilt calculations from the spreadsheet to adjust it?
The NASA data also had a "clear sky" index, possibly that's a factor you can just multiply by to get the average data with weather?
have you had a look at the spreadsheet? There are 2 hidden sheets that do most of the calculations. It’s pretty bloody complicated!!!
