RoadTurtle
- Mar 30, 2022
- 365
2022 Arctic Fox 27-5L, 50a service
Zamp factory 30a controller
2 port cap on roof
one 45w panel & one 170 panel
Rest of planned configuration upgrade below the solar questions
Looking to put on another 170 panel and had a heart attack at Zamp's cost of $599. Led me to HQST 190w panel. Zamp said i have to install a 3 port cap... which had me thinking of pitching the 45w and adding a 2nd 190w panel, but this exceeds the Zamp controller's stated capacity of 510w by 40w. I think I finally understand the wiring and connector issue mixing other brands with Zamp.
Questions
Rest of the system current and immediate upgrade plans
2 port cap on roof
Questions
- Is 550w a problem for Zamp's 30a controller (summer usage in midwest, winter out west and FL)?
- Do I have to replace the 2 port with 3 port?
- 2 GC2 batteries --> 2 Lithium 100a batteries (this is almost as confusing as the panels trying to identify which brand)
- No inverter --> 2200w inverter, which would plug into the 50a generator input I installed on the front, which is wired to generator ready system
- 2500w inverter generator, which is large enough to run front 13.5k AC if needed if most other loads are shed.
- Add panel breaker for on board charger, separating charger from integrated inverter.
