oldsubsailor
I am trying to set up a off grid, no battery well pump for irrigation around the house. Well is 200 ft deep, static water level 40ft. Pump is place at 100 ft. I have a 4 panel array that I have built using Harbor freight panels ThunderBolt 100 watt, 18vdc, 5.56 amps. I have them wired 2S,2P. I am getting 36VOC out of the set up. I bought a pump and controller off ebay. Controller max input is 30V. I am tripping the controller every time the sun gets a little bright. I know that I need to reduce the voltage from the panels. I thought I could just use a step down voltage regulator thinking I could use that only to find out that the regulator will not work on solar or wind generators, I do not understand why this is but it does not work on solar. My question is......how can reduce the output voltage on the panels, or can I obtain a Mppt that will handle the 36 volts and then just take the output off of the Mppt and supply the power to the existing pump controller? There is possibly a very easy solution but trying to set this system up is making me doubt anything that I thought I knew about electricity. Please help
